Broken links in SlimPHP docs
FAlberto
Post by FAlberto » 15 Mar 2019, 15:52
Hi, I follow the docs aimeos-slim and Ifound a lot of broken links.
In the Adapt pages section https://aimeos.org/docs/Slim/Adapt_pages,
which is the Directory Structure in version 2018.10?
the link in the docs say this: https://github.com/aimeos/aimeos-core/t ... lient/Html but I'm not find in the core.
Also, I'm not found the file src/config/shop.php, all this configuration is done in the config/aimeos-settings.php?
Thanks.
Re: Broken links in SlimPHP docs
Post by aimeos » 16 Mar 2019, 11:27
Thank you for your hints, the broken links have been corrected
