Accessing currencies in admin view
Mehdi Guermazi
Post by Mehdi Guermazi » 01 Apr 2019, 18:00
When I click on the menu Locales / Currencies it's a 404 Not found.
This is the url :
/shop/admin/default/jqadm/search/locale%2fcurrency?lang=en
Mehdi Guermazi
Re: Accessing currencies in admin view
Post by Mehdi Guermazi » 01 Apr 2019, 18:13
When I correct the url like this :
/shop/admin/default/jqadm/search/locale/currency?lang=en
Flow doesn't recognize the route
Post by aimeos » 01 Apr 2019, 20:20
Which Aimeos version and environment are you using?
Mehdi Guermazi
Post by Mehdi Guermazi » 01 Apr 2019, 21:33
Just installed Aimeos from github so I think the latest and the latest Flow.
"aimeos/aimeos-flow": "~2018.10"
Mehdi Guermazi
All the second level menu don't work.
Post by aimeos » 03 Apr 2019, 10:09
Which Flow version are you using?
Mehdi Guermazi
Post by Mehdi Guermazi » 04 Apr 2019, 01:08
flow 5.2
Mehdi Guermazi
Post by Mehdi Guermazi » 09 Apr 2019, 17:29
Up!
Post by aimeos » 12 Apr 2019, 07:56
Sorry for the delay, we had to care about the other releases and core bugfixes first. We will fix the problem until we are releasing the new Flow version (scheduled for next week).
Post by aimeos » 15 Apr 2019, 15:05
We've tested now with current Flow 5.2 and Aimeos 2018.10 resp. dev-master. Both work without problem when using this URL:
http://127.0.0.1:8000/index.php/shop/ad ... 2fcurrency
Maybe be a problem with your .htaccess rules? "locale%2fcurrency" must stay as is to be recognized correctly.
