How to Add product manualy from custom controller
awaidqureshi
Post by awaidqureshi » 02 Apr 2019, 11:19
We want to add product from custom controller with product category and attributes(options) ,media with type
Please tell us step by step guide to do that.
We don't want to use csv file.
Thanks .
Re: How to Add product manualy from custom controller
Post by aimeos » 03 Apr 2019, 10:16
The product panel of the admin interface is a good way to see how you can implement that:
https://github.com/aimeos/ai-admin-jqad ... dm/Product
Check the save() and fromArray() methods, e.g. in
- https://github.com/aimeos/ai-admin-jqad ... d.php#L317
You don't have to use the fromArray() methods of the items and you can use the set*() methods instead, e.g.
https://aimeos.org/api/2018/class-Aimeo ... Iface.html
