MSHOP_ORDER_BASE.CUSTOMERID IS "SOMETIMES" EMPTY!!
NOAhgomes
Post by NOAhgomes » 01 May 2019, 12:09
Hello!
Software used:
TYPO3 8.7.18
aimeos 17.10.1
aimeio_pay 17.8.2
Situation:
The shop functionality was extended. Every user is forced to create an user account. The normal checkbox was replaced by a hidden input field.
CODE: SELECT ALL
<?php if( !isset( $this->customerId ) ) : ?>
<input
id="option-account"
type="hidden"
value="1"
name="<?= $enc->attr( $this->formparam( array( 'cs_option_account' ) ) ); ?>"
<?php endif; ?>
This worked like a charm. Expect for less than 0.1% of all orders.
For some reason customerid is sometimes empty. I wasted hours of investigating this behavior but did not found any clue. There are no recurring patterns, errors nor anything that leads to this error.
What I tried out:
- I tried every possible way to order a product but could not reproduce this behavior: F5, cancel order and go back, order as registered user, order as new user, order again and again, etc
- the field customerid was sometimes empty on registered users orders and new users orders aswell
- the field customerid was sometimes empty on any statuspayment
Thank you
Re: MSHOP_ORDER_BASE.CUSTOMERID IS "SOMETIMES" EMPTY!!
Post by aimeos » 02 May 2019, 11:41
The 17.10 version is only supported via the ELTS subscription of the Aimeos company (https://aimeos.com/support). Either you upgrade to a current version or pay them to have a look.
