[SOLVED] Job order/email/payment : "Undefined variable: taxRate"
Re: Job order/email/payment : "Undefined variable: taxRate"
Post by aimeos » 06 Jul 2019, 15:27
Can you add this code here: https://github.com/aimeos/ai-client-htm ... d.php#L235
$context->getLogger()->log( $e->getTraceAsString() );
We need the stack strace you will get in the Log Panel of the admin interface.
Post by aimeos » 06 Jul 2019, 16:03
Can you please run that command:
composer req "aimeos/ai-client-html:2019.07.x-dev"
If it works for you, we will tag a new release afterwards.
Post by aimeos » 06 Jul 2019, 16:21
You didn't do something wrong. The ai-controller-frontend commit with the fix still needs to be tagged. Use that in the meantime:
composer req "aimeos/ai-controller-frontend:2019.07.x-dev"
We will tag it as soon as we have more response.
Post by aimeos » 06 Jul 2019, 16:43
Did you make a copy of the e-mail templates? If yes, they are used instead of the fixed ones
