mshop/price/taxflag set to 0, VAT not added to total
Re: mshop/price/taxflag set to 0, VAT not added to total
Post by aimeos » 07 Jul 2019, 13:13
Copy/paste error in the template. Fixed in 2019.07.x-dev:
composer req "aimeos/ai-client-html:2019.07.x-dev"
Why are the shipping costs missing in your checkout summary?
Post by aimeos » 07 Jul 2019, 16:37
The patch was in the common/summary/detail-standard.php template file. If you copied it, did you adapt it to the updated original one? https://github.com/aimeos/ai-client-htm ... d.php#L382
Post by aimeos » 08 Jul 2019, 09:47
Shipping costs are visible in your basket AND e-mail screenshot, so it doesn't seem to be a general problem because basket and summary share the same template code or isn't this from the same order?
Using "Actual current price" for the delivery service option leads to undesired results in most cases. You should only use the "Shipping/Payment costs" field if you want the shipping costs to be below the subtotal.
Post by aimeos » 08 Jul 2019, 10:33
Fixed duplicate delivery costs row but you should use "Shipping/Payment costs" in the backend nevertheless and use "0.00" as "Actual current price".
