Site-tree in NEOS backend broken when installing Aimeos.Shop
chvonrohr
Post by chvonrohr » 24 Jul 2019, 16:36
Once I install the Aimeos.Shop Plugin in a NEOS installation, the site tree is not loaded anymore and errors are thrown (see below). It seems that "AimeosTypeConverter" that extend Neos\Flow\Property\TypeConverter\MediaTypeConverter is not properly implemented.
I fixed this, by removing the AimeosTypeConverter (the shop seems to work still):
AimeosTypeConverter.php line 29
class AimeosTypeConverter //extends MediaTypeConverter implements MediaTypeConverterInterface
Objects.yaml line 21
# Neos\Flow\Property\TypeConverter\MediaTypeConverterInterface:
#   className: 'Aimeos\Flow\AimeosTypeConverter'
Is this a known issue or is there a possible misconfiguration from my site?
EXCEPTIONS THROWN:
http://mysite/neos/ui-services/get-addi ... e-metadata
Required argument "nodes" is not set.
Exception Code 1298012500
Exception Type Neos\Flow\Mvc\Exception\RequiredArgumentMissingException
Log Reference 20190724161229f1dfdc
Thrown in File Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Neos_Flow_Mvc_Controller_AbstractController.php
Line 382
Original File Packages/Framework/Neos.Flow/Classes/Mvc/Controller/AbstractController.php
http://mysite/neos/ui-services/flow-query
Required argument "chain" is not set.
Log Reference 20190724161223485ac8
Line 382
Re: Site-tree in NEOS backend broken when installing Aimeos.Shop
Post by aimeos » 24 Jul 2019, 20:45
If you disable the AimeosTypeConverter class, some entry points like JSON for frontend and admin interface may not work any more. That depends if the Flow framework has been fixed in the meantime.
If you can get Aimeos to work inside Neos, we would love to get patches from you :-)
