How to make new navigation links in aimeos in admin pannel
awaidqureshi
Post by awaidqureshi » 25 Jul 2019, 06:29
I want to make new navigation links , views and controller and use it in the aimeos admin pannel
Please give step by step guide so that i can do it easily
Re: How to make new navigation links in aimeos in admin pannel
Post by aimeos » 25 Jul 2019, 06:52
There's no documentation for this yet but you can use the existing code as reference, e.g. the attribute panel:
- Classes you need (Factory and Standard): https://github.com/aimeos/ai-admin-jqad ... /Attribute
- Subparts (additional directories) are optional
- Templates you need (list-standard and item-standard): https://github.com/aimeos/ai-admin-jqad ... /attribute
- Add to navigation bar: https://github.com/aimeos/ai-admin-jqad ... navbar.php
- Give permissions: https://github.com/aimeos/ai-admin-jqad ... source.php
whatdaro
Post by whatdaro » 02 Sep 2021, 10:08
hi,
Is there an updated documentation for the current new version please? thanks
Also, is there documentation on how to add links to the userside navbar please.
Post by aimeos » 03 Sep 2021, 06:07
whatdaro wrote: 02 Sep 2021, 10:08 Is there an updated documentation for the current new version please? thanks
There are no relevant changes in the current version so the documentation still applies.
whatdaro wrote: 02 Sep 2021, 10:08 Also, is there documentation on how to add links to the userside navbar please.
You can overwrite the common/page-standard.php template and add your links there:
https://github.com/aimeos/ai-admin-jqad ... andard.php
whatdaro
Post by whatdaro » 05 Sep 2021, 09:31
[/quote]
Thanks for the reply but the second part of my question by "user" I meant the shop front, how to add non-product category menu options. to the main navbar , thanks.
Post by aimeos » 05 Sep 2021, 12:26
Copy the vendor/aimeos/aimeos-laravel/src/views/base.blade.php to resources/views/shop/base.blade.php and add the links to the Blade template:
https://github.com/aimeos/aimeos-larave ... .blade.php
whatdaro
Post by whatdaro » 05 Sep 2021, 13:41
aimeos wrote: 05 Sep 2021, 12:26 Copy the vendor/aimeos/aimeos-laravel/src/views/base.blade.php to resources/views/shop/base.blade.php and add the links to the Blade template:
I've copied the base.blade.php as advised, but the changes I make to it don't load up, only the content from the original.
Should I delete the original?
Also where would I add menu links, when the blade file yields 'aimeos_nav' to build the list from the Catalogs.
If I add additional 'ul>li' list for my extra menu links, they don't display properly.
Post by aimeos » 06 Sep 2021, 06:26
Which Aimeos version are you using? It should be 2021.07.x
You can find the documentation for overwriting the Blade templates here:
https://aimeos.org/docs/latest/laravel/ ... -templates
The aimeos_nav section contains the top-level categories and if you want to add a another link there, you have to add another category. The alternative is that you add your own links beside the categories in a new section like:
<ul><li>new link>/li></ul>
whatdaro
Post by whatdaro » 07 Sep 2021, 22:10
aimeos wrote: 06 Sep 2021, 06:26 The aimeos_nav section contains the top-level categories and if you want to add a another link there, you have to add another category. The alternative is that you add your own links beside the categories in a new section like:
The problem is adding another category points the url to an expected product category page, I want to display a text and image page in the contents, it will not allow me to route to another URL.
Adding another ul section displays after the search, and even if I put it at the front it displays with a large gap between it and the regular navbar.
Post by aimeos » 08 Sep 2021, 05:10
You can fix that with custom CSS rules.
