JSON API AUTH
AlbertoAguilera
JSON API AUTH
Post by AlbertoAguilera » 29 Jul 2019, 20:36
I'm struggling to setup the jsonadm with laravel passport, cause i want to override the admin frontend and build one with react and use password grant tokens to my users, I added the API middleware to the jsonadm route but it keeps popping the login dialog, can you give us a guideline to extend the guard methods of the jsonadm to work with api middleware. Thanks in advance
Re: JSON API AUTH
Post by aimeos » 29 Jul 2019, 21:20
You should ask that question better in a Laravel forum
AlbertoAguilera
Re: JSON API AUTH
Post by AlbertoAguilera » 30 Jul 2019, 18:24
I just read in the docs that aimeos package doesnt overrides the current auth system, i just added the auth:api middleware to the desired route, it seems to work just going to check everything works fine, thx.
