ai-payments | Stripe | SCA Compliance
Re: ai-payments | Stripe | SCA Compliance
Post by aimeos » 10 Sep 2019, 09:10
That depends on the Omnipay driver for Stripe, so you should ask your question here:
https://github.com/thephpleague/omnipay-stripe
patinvedis
Post by patinvedis » 12 Sep 2019, 09:32
I am using the same configuration as the OP.
Could you please be more specific: I would like to know from where (files, classes) I need to call the new sca compliant Stripe API.
The link you have provided is useful to find out the necessary changes to the code, but I cannot find where these changes need to be made in Aimeos.
Thanks for you help
Post by aimeos » 13 Sep 2019, 08:37
You can find the Stripe JS code here:
https://github.com/aimeoscom/ai-payment ... #L217-L302
