Full ckeditor
lucadambros
Full ckeditor
Post by lucadambros » 23 Sep 2019, 12:07
I need the full version of CKEditor in the admin section.
In the file
/vendor/aimeos/aimeos-laravel/src/views/jqadm/index.blade.php
there is the standard version.
How can I overwrite that?
Is there another way?
Re: Full ckeditor
Post by aimeos » 24 Sep 2019, 05:35
You have to add a JS file to your own Aimeos extension that overwrite these lines and which adds all features again:
https://github.com/aimeos/ai-admin-jqad ... js#L12-L19
lucadambros
Re: Full ckeditor
Post by lucadambros » 24 Sep 2019, 06:26
I tried to override that function but plugins like forms won't be enable until I use the full version of ckeditor.
In the official site (https://ckeditor.com/ckeditor-4/download/) there is a different source link for the full package
Re: Full ckeditor
Post by aimeos » 24 Sep 2019, 07:04
Then you have to copy the Aimeos JQAdm Blade template to your ./resources/views/vendor/shop/jqadm/ directory and change that line:
https://github.com/aimeos/aimeos-larave ... de.php#L32
lucadambros
Re: Full ckeditor
Post by lucadambros » 24 Sep 2019, 07:10
Thank you very much! I didin't know that was so easy to do that!
