Insert product into catalog right after creating it
lucadambros
Post by lucadambros » 01 Oct 2019, 10:32
What I want:
1 - I have an array with catalog item ids
2 - I create the product
3- The product is automatically added to the catalog item I have in the array.
Example:
The array has the ids: 1, 2.
I create the product and it will be displayed into the catalog item 1 and 2.
Is that possibile?
What do I have to override?
I have laravel 5.8 and Aimeos 2019.07
Thank you very much
Re: Insert product into catalog right after creating it
Post by aimeos » 01 Oct 2019, 11:44
In the admin interface or within your self written code?
lucadambros
Post by lucadambros » 01 Oct 2019, 11:55
Written code.
I think I have to override the function "save" inside
 ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Product/Standard.php
Post by aimeos » 01 Oct 2019, 12:07
You can use the product category subpart as reference:
https://github.com/aimeos/ai-admin-jqad ... #L382-L404
lucadambros
Post by lucadambros » 01 Oct 2019, 13:13
Great as always! Thank you very much!
Aimeos product is fantastic
