DB explanation - mshop_media
lucadambros
Post by lucadambros » 09 Oct 2019, 10:27
I need to know more about the mshop_media table. The field "preview" is quite hard to understand for me.
How that work?
I have raw data and I want to insert it into that table (links for image products). How the json is created?
I mean, why sometimes you start with
{"1": ...
and other times you start with
{"240": ...
Thank you very much
Re: DB explanation - mshop_media
Post by aimeos » 09 Oct 2019, 11:43
The JSON in the "preview" column represents the different preview image sizes with the width of the image in px as key (e.g. "240"). If an image doesn't has a size (e.g. SVG) or isn't an image, than "1" px width is used as key.
lucadambros
Post by lucadambros » 09 Oct 2019, 11:52
Thank you very much! :D
