Product > Price > Option "Substract Rebate Amount" // Company field in checkout
cyrotek
Post by cyrotek » 06 Nov 2019, 08:07
I've entered a value into the substract rebate amount, but nothing is happening? Do I need to add a decorator or anything for it work??
I suppose Its supposed to give the User a feel of discounted product or what is it supposed to do?
EDIT: Also how can i make the company field visible per default and remove it from the salutation?
Re: Product > Price > Option "Substract Rebate Amount" // Company field in checkout
Post by aimeos » 06 Nov 2019, 18:37
In the default template, the reduction in percent is calculated and shown:
The company field is displayed/hidden using that JS code:
https://github.com/aimeos/ai-client-htm ... 1713-L1743
Salutations are configurable:
- https://aimeos.org/docs/Configuration/C ... alutations
