Cache into database
Skupiewski
Cache into database
Post by Skupiewski » 07 Nov 2019, 15:42
Hello
I try to cache aimeos (laravel) into my database.
There is no manager into ai-cache to do to that.
I tried to configure aimeos to use the standard laravel cache system, but there is no documentation about that anywhere.
I begin to thing Aimeos is not able to do this simple stuff...
So, my question is -> Is that possible to cache aimeos into a database without reprogramming Aimeos.
If not, Why ?
Thank you :-)
Re: Cache into database
Post by aimeos » 07 Nov 2019, 18:56
Storing the cached entries into the database is the default but Aimeos uses it's own table (madmin_cache)
Skupiewski
Post by Skupiewski » 08 Nov 2019, 17:13
Haaa yes indeed, Thank you :-)
So now.
I have a page which is impossible to debug because of the cache.
Event i change URL parameters, the page stay the same.
I tried all commands to clean caches but no way.
My questions is -> What is the best way to desable cache for development area ?
Thanks... :-)
Post by aimeos » 09 Nov 2019, 11:41
If you enable these two settings in your ./config/shop.php, no caching will occur at all:
- https://github.com/aimeos/aimeos-larave ... op.php#L65
- https://github.com/aimeos/aimeos-larave ... op.php#L85
