Category tree depth
flomo
Category tree depth
Post by flomo » 14 Nov 2019, 11:21
How can I increase the depth of the category tree in the filter section? I found this configuration, but it is only for Aimeos 2018 https://aimeos.org/docs/Configuration/C ... els-always
Then I checked the catalog/filter/tree-body-standard template and found out that Aimeos\MShop\Catalog\Item\Standard generates the root and the direct children. But there is no possibility to iterate deeper thant level 1?
Re: Category tree depth
Post by aimeos » 15 Nov 2019, 08:58
The configuration has been moved to the controller frontend package an will display as many levels automatically as you configure:
flomo
Post by flomo » 15 Nov 2019, 13:55
Thanks for pointing that out.
I've added a link from the documentation of the old configuration to the new one.
