disable-new address
columbo
disable-new address
Post by columbo » 18 Nov 2019, 22:46
Hi
according to documentation the current setting to disable new addresses is:
client/html/checkout/standard/address/billing/disable-new => 1
https://aimeos.org/docs/Configuration/C ... isable-new but when I use this setting, the form still apperas.
But when I use the old one, that is deprecated since 2015-02
client/html/common/address/billing/disable-new => 1
https://aimeos.org/docs/Configuration/C ... isable-new it works.
Is the documentation not correct or do I have any other cofiguration issues?
thank you
Re: disable-new address
Post by aimeos » 19 Nov 2019, 22:40
is correct. The other setting was introduced later but seems to be removed again, so it's a documentation issue. Current code in the template is: https://github.com/aimeos/ai-client-htm ... rd.php#L28
