display variant attributes on catalog page
columbo
Post by columbo » 23 Nov 2019, 10:32
I'd like to display Variant attributes (eg. salesunit) on the catalog page.
I tried
$productItem->getRefItems( 'attribute', null, 'variant' ),
in a cutom version of
/ext/ai-client-html/client/html/templates/catalog/lists/items-body-list.php
but it still does not work.
I'm using the wrong mehtod? Are there other / better possibilities to display variant attributes?
Re: display variant attributes on catalog page
Post by aimeos » 25 Nov 2019, 10:03
The attributes are not fetched by default in the list view. You can get them if you add "attribute" to this configuration:
https://aimeos.org/docs/Configuration/C ... ts/domains
columbo
Post by columbo » 26 Nov 2019, 22:54
I added 'attribute' to client/html/catalog/lists/domains:
'domains' => [
    0 => 'media',
    1 => 'price',
    2 => 'text',
    3 => 'attribute'
but I still do not get any value for attributes definded under:
Products > Characteristic > Variant attributes > salesunit
I tried:
$productItem->getRefItems( 'attribute', null, 'variant' );
$productItem->getRefItems( 'variant', null, 'salesunit' );
Post by aimeos » 28 Nov 2019, 09:32
is correct but variant attributes are not attached to the selection product. Instead, they are part of the articles that are referenced by the selection product and you have to fetch them as well:
'domains' => [
    0 => 'media',
    1 => 'price',
    2 => 'text',
    3 => 'attribute'
    4 => 'product'
Then, you can loop over the articles and get their variant attributes:
foreach( $product->getRefItems( 'product', null, 'default' ) as $article ) {
	$attrItems = $article->getRefItems( 'attribute', null, 'variant' );
The product partial already does that if the "basket-add" configuration is enabled:
https://github.com/aimeos/ai-client-htm ... #L254-L287
columbo
Post by columbo » 28 Nov 2019, 23:01
unfortunately it's not working.
For a simple test I added just this code on my catalog/lists page:
<?php
    foreach( $productItem->getRefItems( 'product', null, 'default' ) as $article ) {
        echo $article;
        echo $attrItems;
but I get on values either for $article nor $attrItems.
I'd like to list all variants with their sailesunit (e.g. kg, ml, g,) on a catalog page
Post by aimeos » 29 Nov 2019, 12:09
Use the "client/html/catalog/lists/basket-add" configuration setting, which does this already for you:
https://aimeos.org/docs/Configuration/C ... basket-add
