Override class in Classes/Base/
cnoelker
Post by cnoelker » 18 Dec 2019, 12:51
what is the correct way to override a class in Classes/Base/ , in the aimeos TYPO3 extension?
Claudia
Re: Override class in Classes/Base/
Post by aimeos » 19 Dec 2019, 07:22
Add a closure function to the ext_localconf.php of your Aimeos TYPO3 extension for your project that returns the object implementation you need, e.g.
$GLOBALS['TYPO3_CONF_VARS']['EXTCONF']['aimeos']['aimeos_context'] = function( $config ) {
	return new Mycontext( $config );
Check the Aimeos base class to see what objects you can overwrite and how:
https://github.com/aimeos/aimeos-typo3/ ... s/Base.php
cnoelker
Post by cnoelker » 19 Dec 2019, 08:58
Thank you, it works. :)
