Run Aimeos jobs in Laravel controller
D-Cell
Post by D-Cell » 21 Dec 2019, 21:09
Hello! I`m writing custom product import script for my project.
It helps the shop admin to choose which columns from Excel file have to be imported.
After admin finishes, the script saves the final CSV file to my local storage (public/csv/products directory).
After that i have to run
php artisan aimeos:jobs product/import/csv myshop
in console to import products.
What i try to achieve is running
in my controller, not in console.
Laravel allows me to run console commands in controllers using Artisan::call() function, so i tried next:
Artisan::call('aimeos:jobs', ['jobs' => 'product/import/csv', 'site' => 'smartshop']);
and
Artisan::call('aimeos:jobs product/import/csv smartshop');
Unfortunately, none of those options didn't give any result.
Is there any way to run Aimeos jobs within Laravel controller?
System: Aimeos 2019.07, Laravel 5.8, Fedora 30, PHP 7.3
Thank you for your time and have a happy upcoming holidays!
Re: Run Aimeos jobs in Laravel controller
Post by aimeos » 24 Dec 2019, 13:07
If nothing works, you can also implement the code from the aimeos:jobs command directly:
https://github.com/aimeos/aimeos-larave ... nd.php#L47
tulparstudyo
Post by tulparstudyo » 27 Feb 2021, 10:09
Hello, I have created a job controller to importing products from xlsx file.
The controller working correctly on console command
php artisan aimeos:jobs "product/import/xlsx" "default"
php artisan aimeos:jobs "product/export/xlsx" "default"
I want to implement this job controler like aimeos: $Xlsx = new \Aimeos\Shop\Command\JobsCommand();
How can I do the implementing and configure this JobsCommand;
Post by aimeos » 01 Mar 2021, 10:51
Don't know if this is really useful but if you want to have an own, specific command, you can use the aimeos:jobs command as reference:
https://github.com/aimeos/aimeos-larave ... ommand.php
tulparstudyo
Post by tulparstudyo » 03 Mar 2021, 08:45
Thanks,
I solved the problem. Now I can product import and product export on the admin panel by xlsx file upload.
https://github.com/tulparstudyo/sw-xlsx
veeran ambalam
Post by veeran ambalam » 23 Apr 2021, 16:44
@tulparstudyo Can you please explain this "https://github.com/tulparstudyo/sw-xlsx"
