Getting Error While Product Adding To Basket
awaidqureshi
Post by awaidqureshi » 06 Jan 2020, 06:47
I m getting this error while adding product in to the basket.
Invalid "attribute" references for product with ID "411"
What can be the issue , how can i solve this
Thanks.
Re: Getting Error While Product Adding To Basket
Post by aimeos » 07 Jan 2020, 13:06
This is an exception from the basket controller:
https://github.com/aimeos/ai-controller ... p#L89-L118
The variant/config/custom attribute IDs you've passed to the basket when hitting "Add to basket" are not all associated to the product. Maybe the format of the POST parameters is wrong:
https://aimeos.org/docs/Developers/Html ... mes#Basket
