Getting site code giving error
adityabanerjee
Post by adityabanerjee » 11 Jan 2020, 10:29
Hi I have extended the getSession and setSession methods from the Base.php. I have created my own php file named Ebdaa.php
my Ebdaa.php looks like
<?php
namespace Aimeos\MShop\Order\Manager\Base;
class Ebdaa extends Standard
	public function getSession($type = 'default')
        $session = $context->getSession();
        $locale = $context->getLocale();
        $currency = $locale->getCurrencyId();
        $language = $locale->getLanguageId();
        $sitecode = $locale->getSiteItem()->getCode();
        $key = 'aimeos/basket/lock-' . $sitecode . '-' . $language . '-' . $currency . '-' . strval( $type );
        if( ( $value = $session->get( $key ) ) !== null ) {
            return (int) $value;
        return \Aimeos\MShop\Order\Manager\Base\Base::LOCK_DISABLE;
	 * Saves the current shopping basket of the customer.
	 * @param \Aimeos\MShop\Order\Item\Base\Iface $order Shopping basket
	 * @param string $type Order type if a customer can have more than one order at once
	 * @return \Aimeos\MShop\Order\Manager\Base\Iface Manager object for chaining method calls
    public function setSession( \Aimeos\MShop\Order\Item\Base\Iface $order, $type = 'default')
    	dd('in set session');
Now I am facing an error-:
Symfony\Component\Debug\Exception\FatalThrowableError: Call to undefined method Aimeos\MShop\Locale\Item\Standard::getSiteItem() in file /Users/adityabanerjee/code/ebdaa-ecommerce-beta/ext/ebdaa/lib/custom/src/MShop/Order/Manager/Base/Ebdaa.php on line 14
Please assist.
Re: Getting site code giving error
Post by aimeos » 12 Jan 2020, 17:50
You are using the code from the master branch but your installed version is 2019.10.
The getSite() method in 2019.10 has been renamed to getSiteItem() in master.
