Override catalog/lists/standard/template-body gives error undefined function map()
pixelplumber
Hi, I created an extension for TYPO3 with your kickstarter and tried to override the client.html.catalog.lists.standard.template-body to remove the list-type (grid/list) widgets. My override template (just a copied body-standard minus lines 139-147) causes a fatal error:
Call to undefined function map()
Line 11: $catPath = $this->get( 'listCatPath', map() );
Do I need something extra in my extensions composer.json to autoload the definition for map()? I only have the default client/src directories, do the template directories need to be added too?
It works if I just use the built-in standard template.
Cheers.
env: TYPO3 9.5.13, Aimeos 9.10. php 7.3 Linux
Cheers.
aimeos/ai-admin-jqadm 2019.10.9
aimeos/ai-admin-jsonadm 2019.10.3
aimeos/ai-client-html 2019.10.12
aimeos/ai-client-jsonapi 2019.10.3
aimeos/ai-controller-frontend 2019.10.8
aimeos/ai-controller-jobs 2019.10.9
aimeos/ai-gettext 2019.10.1
aimeos/ai-typo3 2019.10.5
aimeos/aimeos-core 2019.10.16
aimeos/aimeos-typo3 19.10.4-
pixelplumber
Re: Override catalog/lists/standard/template-body gives error undefined function map()
<facepalm> copied body-standard off ai-client master branch and not the 2019.10 branch.
All good now.
Incidentally, if I try an upgrade to 2020.1 in typo3 the pagination/sorting widgets all stop working - there are no request paramaters attached just the page URL so any clicks just reload the page.
Anyone else seen this?
All good now.
2020.01 is beta so there are some bugs for sure and we will check that.
Doesn't seem to be a general problem. Maybe it's related to the route enhancer configuration you are using.pixelplumber wrote: 03 Feb 2020, 01:44 Incidentally, if I try an upgrade to 2020.1 in typo3 the pagination/sorting widgets all stop working - there are no request paramaters attached just the page URL so any clicks just reload the page.
