Getting the current language in Aimeos
Amir
Post by Amir » 22 Feb 2020, 17:46
I want to check the current language to switch the HTML rendering from Left To Right to Right To Left. I've checked it using
 dir="{{ Lang::locale() === "en" ? "ltr" : "rtl" }}"
but it always displays ltr. How to achieve that?
Re: Getting the current language in Aimeos
Post by aimeos » 24 Feb 2020, 08:44
You can use
App::isLocale('en')
Amir
Post by Amir » 24 Feb 2020, 12:33
the code
App::isLocale('en')
returns 1 which will always display one direction only, I'm using the select/locale switcher from aimeos.
And I tried setting the locale in the service provider to get it to work and it does, but the product language are independent from the global locale I've set.
Post by aimeos » 24 Feb 2020, 13:56
Aimeos is using the "locale" parameter and you can set it in a custom middleware to that value so it's available in the App facade:
https://dev.to/fadilxcoder/adding-multi ... ravel-4ech
