configure the base URL to the Aimeos JSON API
JuanMRuiz
Post by JuanMRuiz » 23 Apr 2020, 07:22
how I can?
configure the base URL to the Aimeos JSON API of the instance you want to connect to in your client application
thank you
Re: configure the base URL to the Aimeos JSON API
Post by aimeos » 23 Apr 2020, 20:46
Do you want to set up a multi vendor installation?
If yes, your have to adapt the routing: https://aimeos.org/docs/Laravel/Configu ... iple_shops
Then it's usually https://domain.tld/<sitecode>/jsonapi/
If no, it's always https://domain.tld/jsonapi/
This is the main entry point you have to start with an OPTIONS request.
