Can't delete multiple products from admin
JoseBibiloni
When trying to delete multiple products using the checkboxes and then the x at the top of the checkboxes I get a confirmation asking if I want to delete the items selected and lists them but once you confirm I get the following error:
Using Laravel 5.8, Aimeos 2020.04, PHP 7.2, Ubuntu 18.04
"Class "\Aimeos\Admin\JQAdm\Product\En\Factory" not available"Using Laravel 5.8, Aimeos 2020.04, PHP 7.2, Ubuntu 18.04
Re: Can't delete multiple products from admin
Laravel 5.x has a routing bug assigning any parameter to an optional route parameter. If you can, upgrade to Laravel 6
JoseBibiloni
Would love to but there are limitations I can't control that makes me stay in 5.x Is there another workaround I could do? Anything I should search for specifically?aimeos wrote: 25 Apr 2020, 08:01 Laravel 5.x has a routing bug assigning any parameter to an optional route parameter. If you can, upgrade to Laravel 6
Possible workaround could be to add an empty "id" parameter here if it doesn't exist:
https://github.com/aimeos/ai-admin-jqad ... #L515-L516
JoseBibiloni
Do you mean something like $searchParams['id'] = ''; ?aimeos wrote: 29 Apr 2020, 17:19 Possible workaround could be to add an empty "id" parameter here if it doesn't exist:
I added that but the problem persists. I am looking to upgrade but no success yet so I am trying the workaround.
That workaround works: https://github.com/aimeos/ai-admin-jqad ... 5c55590b28
Use
until the new version is tagged.
Use
composer req aimeos/ai-admin-jqadm:2020.04.x-devProfessional support and custom implementation are available at Aimeos.com
JoseBibiloni
worked perfectly thank you!aimeos wrote: 14 May 2020, 17:43 That workaround works: https://github.com/aimeos/ai-admin-jqad ... 5c55590b28
Useuntil the new version is tagged.Code: Select all
