API Override
saikano
API Override
Post by saikano » 19 May 2020, 18:36
Hi, I want to make some kind of wrap items in catalog, and special logic for items/products and write own API, how can I do that with Laravel package?
I use latest version of package, php 7.2 on MacOS
Re: API Override
Post by aimeos » 22 May 2020, 07:18
Depends on what you exactly want to do. If you provide more information, we can suggest the best way.
saikano
Re: API Override
Post by saikano » 22 May 2020, 12:06
I want to add new category of products - promotional product. This product is special, customer can't buy it, only get it if some conditions a met.
For example - special product Teddy Bear. Every one get it if spent 1000$ in this month and if customer's email starts with "ted". If conditions are met, then customer get Teddy Bear in next delivery
Re: API Override
Post by aimeos » 22 May 2020, 13:14
Implement a delivery service provider that implements the rules and updates the basket accordingly:
https://aimeos.org/docs/Developers/Library/Service
