currency format not working
carlos_valdes
Post by carlos_valdes » 05 Jun 2020, 16:44
Hi, i have a problem displaying MXN peso format.
the correct format is like this $ 1,000,000.00
but prices continue to display as
$1.000.000.00
here is my config:
'i18n' => [
'es' => [
'currency' => [
'MXN' => '$',
'client/code' => [
'price:default' => ['%2$s %1$s'],
'%1$s %2$s' => ['%2$s %1$s'],
'client' => [
Re: currency format not working
Post by aimeos » 06 Jun 2020, 10:40
The number format depends on the language and the PHP locale based number formatter uses the european number format for "es". You should add "es_MX" as language in the "Locale -> Language" panel in the admin interface and use it in the "Locale -> Locale" panel instead of "es". Then it should work.
carlos_valdes
Post by carlos_valdes » 07 Jun 2020, 03:11
Perfect, solved! :D
