Relate attribute to catalog
In admin panel I can connect attribute to product, all data saved to mshop_index_attribute.
If I can in admin panel connect attribute to catalog item? Or I need to create custom extension?
If custom extension, creating new table which consist foreign keys from mshop_catalog and mshop_product is a good approach?
Thank you
Thank you
Re: Relate attribute to catalog
You can attach attributes to categories using the mshop_catalog_list table. You only have to implement a sub-panel similar to the catalog product sub-panel:
https://github.com/aimeos/ai-admin-jqad ... andard.php
Also have a look at this thread:
post6044.html#p6044
post6044.html#p6044
Thank you for reply,
I created my extension with name test
I aded in composer in classmap:
Then in ./ext/test/config/admin.php I added subpart:
But I don't understand why aimeos search Test class in \Aimeos\Admin\JQAdm\Catalog\Test\Standard, but not in my extension.
I got an error:"Class "\Aimeos\Admin\JQAdm\Catalog\Test\Standard" not available"
Also when I add this class in \Aimeos\Admin\JQAdm\Catalog\Test\Standard in ai-admin-qadm I can see subpart test in catalog, but when I press on it it does nothing.
"autoload": {
"classmap": [
"ext/<yourext>/lib/custom/src",
"ext/<yourext>/controller/common/src",
"ext/<yourext>/controller/frontend/src",
"ext/<yourext>/controller/jobs/src",
"ext/<yourext>/client/html/src",
"ext/<yourext>/client/jsonapi/src",
"ext/<yourext>/admin/html/src",
"ext/<yourext>/admin/jsonadm/src"
},Code: Select all
'jqadm' => [
'catalog' =>[
'standard' => [
'subparts' => [
'test'
],I got an error:"Class "\Aimeos\Admin\JQAdm\Catalog\Test\Standard" not available"
I did composer dump-autload and my extension working.
But I have a problem with subpart
This is admin.php in my ext:
Then I created Test folder in my extension in jqadm/src/Catalog/Test/Standard.php
This is content of file:
I see test tab in admin->catagories. But when I tap on button Test it does nothing
'catalog' =>[
'standard' => [
'subparts' => [
'test'
]This is content of file:
<?php
* @copyright Aimeos (aimeos.org), 2017-2020
* @package Admin
* @subpackage JQAdm
namespace Aimeos\Admin\JQAdm\Catalog\Test;
sprintf( 'attribute' ); // for translation
* Default implementation of catalog product JQAdm client.
* @package Admin
* @subpackage JQAdm
class Standard
extends \Aimeos\Admin\JQAdm\Common\Admin\Factory\Base
implements \Aimeos\Admin\JQAdm\Common\Admin\Factory\Iface
/** admin/jqadm/catalog/product/name
* Name of the product subpart used by the JQAdm catalog implementation
* Use "Myname" if your class is named "\Aimeos\Admin\Jqadm\Catalog\Product\Myname".
* The name is case-sensitive and you should avoid camel case names like "MyName".
* @param string Last part of the JQAdm class name
* @since 2017.07
* @category Developer
* Adds the required data used in the template
* @param \Aimeos\MW\View\Iface $view View object
* @return \Aimeos\MW\View\Iface View object with assigned parameters
public function addData( \Aimeos\MW\View\Iface $view ) : \Aimeos\MW\View\Iface
$manager = \Aimeos\MShop::create( $this->getContext(), 'catalog/lists/type' );
$search = $manager->createSearch( true )->setSlice( 0, 10000 );
$search->setConditions( $search->compare( '==', 'catalog.lists.type.domain', 'product' ) );
$search->setSortations( [$search->sort( '+', 'catalog.lists.type.position' )] );
$view->productListTypes = $manager->searchItems( $search );
return $view;
* Copies a resource
* @return string|null HTML output
public function copy() : ?string
$view = $this->getObject()->addData( $this->getView() );
$view->productBody = '';
foreach( $this->getSubClients() as $client ) {
$view->productBody .= $client->copy();
return $this->render( $view );
* Creates a new resource
public function create() : ?string
$view->productBody .= $client->create();
* Returns a single resource
public function get() : ?string
$total = 0;
$params = $this->storeSearchParams( $view->param( 'cp', [] ), 'catalogproduct' );
$listItems = $this->getListItems( $view->item, $params, $total );
$view->productItems = $this->getProductItems( $listItems );
$view->productData = $this->toArray( $listItems );
$view->productTotal = $total;
$view->productBody .= $client->get();
* Saves the data
public function save() : ?string
$view = $this->getView();
$manager = \Aimeos\MShop::create( $this->getContext(), 'catalog/lists' );
$manager->begin();
try
$this->fromArray( $view->item, $view->param( 'product', [] ) );
$view->productBody .= $client->save();
$manager->commit();
catch( \Exception $e )
$manager->rollback();
throw $e;
return null;
* Returns the sub-client given by its name.
* @param string $type Name of the client type
* @param string|null $name Name of the sub-client (Default if null)
* @return \Aimeos\Admin\JQAdm\Iface Sub-client object
public function getSubClient( string $type, string $name = null ) : \Aimeos\Admin\JQAdm\Iface
/** admin/jqadm/catalog/product/decorators/excludes
* Excludes decorators added by the "common" option from the catalog JQAdm client
* Decorators extend the functionality of a class by adding new aspects
* (e.g. log what is currently done), executing the methods of the underlying
* class only in certain conditions (e.g. only for logged in users) or
* modify what is returned to the caller.
* This option allows you to remove a decorator added via
* "admin/jqadm/common/decorators/default" before they are wrapped
* around the JQAdm client.
* admin/jqadm/catalog/product/decorators/excludes = array( 'decorator1' )
* This would remove the decorator named "decorator1" from the list of
* common decorators ("\Aimeos\Admin\JQAdm\Common\Decorator\*") added via
* "admin/jqadm/common/decorators/default" to the JQAdm client.
* @param array List of decorator names
* @since 2017.07
* @see admin/jqadm/common/decorators/default
* @see admin/jqadm/catalog/product/decorators/global
* @see admin/jqadm/catalog/product/decorators/local
/** admin/jqadm/catalog/product/decorators/global
* Adds a list of globally available decorators only to the catalog JQAdm client
* This option allows you to wrap global decorators
* ("\Aimeos\Admin\JQAdm\Common\Decorator\*") around the JQAdm client.
* admin/jqadm/catalog/product/decorators/global = array( 'decorator1' )
* This would add the decorator named "decorator1" defined by
* "\Aimeos\Admin\JQAdm\Common\Decorator\Decorator1" only to the JQAdm client.
* @since 2017.07
* @see admin/jqadm/catalog/product/decorators/excludes
/** admin/jqadm/catalog/product/decorators/local
* Adds a list of local decorators only to the catalog JQAdm client
* This option allows you to wrap local decorators
* ("\Aimeos\Admin\JQAdm\Catalog\Decorator\*") around the JQAdm client.
* admin/jqadm/catalog/product/decorators/local = array( 'decorator2' )
* This would add the decorator named "decorator2" defined by
* "\Aimeos\Admin\JQAdm\Catalog\Decorator\Decorator2" only to the JQAdm client.
* @since 2017.07
return $this->createSubClient( 'catalog/product/' . $type, $name );
* Returns the catalog list items referencing the products
* @param \Aimeos\MShop\Catalog\Item\Iface $item Catalog item object
* @param array $params Associative list of GET/POST parameters
* @param integer $total Value/result parameter that will contain the item total afterwards
* @return \Aimeos\Map Catalog list items implementing \Aimeos\MShop\Common\Item\List\Iface referencing the products
protected function getListItems( \Aimeos\MShop\Catalog\Item\Iface $item, array $params = [], &$total = null ) : \Aimeos\Map
$search->sort( '+', 'catalog.lists.position' ),
$search->sort( '+', 'catalog.lists.refid' )
$search = $this->initCriteria( $search, $params, 'catalogproduct' );
$expr = [
$search->getConditions(),
$search->compare( '==', 'catalog.lists.parentid', $item->getId() ),
$search->compare( '==', 'catalog.lists.domain', 'product' ),
$search->setConditions( $search->combine( '&&', $expr ) );
return $manager->searchItems( $search, [], $total );
* Returns the product items referenced by the given list items
* @param \Aimeos\Map $listItems Catalog list items implementing \Aimeos\MShop\Common\Item\List\Iface and referencing the products
* @return \Aimeos\Map List of product IDs as keys and items implementing \Aimeos\MShop\Product\Item\Iface
protected function getProductItems( \Aimeos\Map $listItems ) : \Aimeos\Map
$list = $listItems->getRefId()->toArray();
$manager = \Aimeos\MShop::create( $this->getContext(), 'product' );
$search = $manager->createSearch()->setSlice( 0, count( $list ) );
$search->setConditions( $search->compare( '==', 'product.id', $list ) );
return $manager->searchItems( $search );
* Returns the list of sub-client names configured for the client.
* @return array List of JQAdm client names
protected function getSubClientNames() : array
/** admin/jqadm/catalog/product/standard/subparts
* List of JQAdm sub-clients rendered within the catalog product section
* The output of the frontend is composed of the code generated by the JQAdm
* clients. Each JQAdm client can consist of serveral (or none) sub-clients
* that are responsible for rendering certain sub-parts of the output. The
* sub-clients can contain JQAdm clients themselves and therefore a
* hierarchical tree of JQAdm clients is composed. Each JQAdm client creates
* the output that is placed inside the container of its parent.
* At first, always the JQAdm code generated by the parent is printed, then
* the JQAdm code of its sub-clients. The product of the JQAdm sub-clients
* determines the product of the output of these sub-clients inside the parent
* container. If the configured list of clients is
* array( "subclient1", "subclient2" )
* you can easily change the product of the output by reproducting the subparts:
* admin/jqadm/<clients>/subparts = array( "subclient1", "subclient2" )
* You can also remove one or more parts if they shouldn't be rendered:
* admin/jqadm/<clients>/subparts = array( "subclient1" )
* As the clients only generates structural JQAdm, the layout defined via CSS
* should support adding, removing or reproducting content by a fluid like
* design.
* @param array List of sub-client names
* @since 2017.07
return $this->getContext()->getConfig()->get( 'admin/jqadm/catalog/product/standard/subparts', [] );
* Creates new and updates existing items using the data array
* @param \Aimeos\MShop\Catalog\Item\Iface $item Catalog item object without referenced domain items
* @param array $data Data array
* @return \Aimeos\MShop\Catalog\Item\Iface Modified catalog item
protected function fromArray( \Aimeos\MShop\Catalog\Item\Iface $item, array $data ) : \Aimeos\MShop\Catalog\Item\Iface
$listIds = $this->getValue( $data, 'catalog.lists.id', [] );
$listManager = \Aimeos\MShop::create( $this->getContext(), 'catalog/lists' );
$search = $listManager->createSearch()->setSlice( 0, count( $listIds ) );
$search->setConditions( $search->compare( '==', 'catalog.lists.id', $listIds ) );
$listItem = $listManager->createItem();
$listItem->setParentId( $item->getId() );
$listItem->setDomain( 'product' );
foreach( (array) $listIds as $idx => $listid )
if( isset( $listItems[$listid] ) ) {
$litem = $listItems[$listid];
} else {
$litem = clone $listItem;
$litem->setId( $listid ?: null );
if( isset( $data['catalog.lists.refid'][$idx] ) ) {
$litem->setRefId( $this->getValue( $data, 'catalog.lists.refid/' . $idx ) );
if( isset( $data['catalog.lists.status'][$idx] ) ) {
$litem->setStatus( (int) $this->getValue( $data, 'catalog.lists.status/' . $idx ) );
if( isset( $data['catalog.lists.type'][$idx] ) ) {
$litem->setType( $this->getValue( $data, 'catalog.lists.type/' . $idx ) );
if( isset( $data['catalog.lists.position'][$idx] ) ) {
$litem->setPosition( (int) $this->getValue( $data, 'catalog.lists.position/' . $idx ) );
if( isset( $data['catalog.lists.datestart'][$idx] ) ) {
$litem->setDateStart( $this->getValue( $data, 'catalog.lists.datestart/' . $idx ) );
if( isset( $data['catalog.lists.dateend'][$idx] ) ) {
$litem->setDateEnd( $this->getValue( $data, 'catalog.lists.dateend/' . $idx ) );
if( isset( $data['catalog.lists.config'][$idx] )
&& ( $conf = json_decode( $this->getValue( $data, 'catalog.lists.config/' . $idx ), true ) ) !== null
$litem->setConfig( $conf );
if( isset( $data['config'][$idx]['key'] ) )
$conf = [];
foreach( (array) $data['config'][$idx]['key'] as $pos => $key )
if( trim( $key ) !== '' && isset( $data['config'][$idx]['val'][$pos] ) ) {
$conf[$key] = $data['config'][$idx]['val'][$pos];
$listManager->saveItem( $litem, false );
return $item;
* Constructs the data array for the view from the given item
* @param \Aimeos\Map $listItems Catalog list items implementing \Aimeos\MShop\Common\Item\Lists\Iface and referencing the products
* @return string[] Multi-dimensional associative list of item data
protected function toArray( \Aimeos\Map $listItems ) : array
$data = [];
foreach( $listItems as $listItem )
foreach( $listItem->toArray( true ) as $key => $value ) {
$data[$key][] = $value;
return $data;
* Returns the rendered template including the view data
* @param \Aimeos\MW\View\Iface $view View object with data assigned
* @return string HTML output
protected function render( \Aimeos\MW\View\Iface $view ) : string
/** admin/jqadm/catalog/product/template-item
* Relative path to the HTML body template of the product subpart for catalogs.
* The template file contains the HTML code and processing instructions
* to generate the result shown in the body of the frontend. The
* configuration string is the path to the template file relative
* to the templates directory (usually in admin/jqadm/templates).
* You can overwrite the template file configuration in extensions and
* provide alternative templates. These alternative templates should be
* named like the default one but with the string "default" replaced by
* an unique name. You may use the name of your project for this. If
* you've implemented an alternative client class as well, "default"
* should be replaced by the name of the new class.
* @param string Relative path to the template creating the HTML code
* @since 2016.04
$tplconf = 'admin/jqadm/catalog/product/template-item';
$default = 'catalog/item-attribute-standard';
return $view->render( $view->config( $tplconf, $default ) );
As long as you add no template ./templates/catalog/item-attribute-standard.php, there will be no output.
Thank you, I resolved my mistake. I did composer dump-autoload and all work.
Also I changed all variables in item-attribute-standard.php to attribute and ibuttonwork!
I got from Products tab subpart Options and put in catalog.
Then I want to save data which in options I added.
How can I do this.
I found method save() in
But I got an error message in this line of code:
How can I do this.
namespace Aimeos\Admin\JQAdm\Catalog;Code: Select all
ErrorError saving dataCode: Select all
return $manager->insertItem( $item, $data['catalog.parentid'] ?: null );Re: Relate attribute to catalog
I added options in catalog like this is in products.
I resolved all errors and saved options to mshop_catalog_list with domain attribute.
Then I need to show all options related to catelog in options subpart.
How I can do this, I try to debug code in Catalog/Standart.php, but cannot find something.
I attached file where I want to show attributes related to catalog.
Thank you
Thank you
- options.png (28.48 KiB) Viewed 9589 times
Use the code in the product characteristics panel as reference for saving the attribute references:
https://github.com/aimeos/ai-admin-jqad ... acteristic
