Vue storefront
harshithvemula
Vue storefront
Post by harshithvemula » 19 Jul 2020, 16:39
Hii i want to integrate vue storefront with pwa to aimeos. How to do it ?
Api is the only way or can we adapt the theme ?
If only with Api how to make variable products,downloadable products is there any code avilable. Or is it possible by adapting the theme.If yes how to do it ?
Re: Vue storefront
Post by aimeos » 21 Jul 2020, 09:26
To use VueStorefront as frontend for Aimeos, you can either implement the API VueStorefront requires in Aimeos or you can adapt the VueStorefront code to use the Aimeos JSON REST API.
harshithvemula
Re: Vue storefront
Post by harshithvemula » 21 Jul 2020, 10:24
can you explain how to adapt ? Can i use the front end code of aimeos in doing it ?
harshithvemula
Re: Vue storefront
Post by harshithvemula » 22 Jul 2020, 14:41
I want to use the frontend code of aimeos in vue store front. For example i want to use the below code in vue and build the vue storefront.How to do it.where i need to place the vue files to do this ?
please help me
@extends('shop::base')
@section('aimeos_header')
<?= $aiheader['checkout/standard'] ?>
@stop
@section('aimeos_body')
<?= $aibody['checkout/standard'] ?>
@stop
