updating aimeos core
bilginkilic
Post by bilginkilic » 20 Jul 2020, 13:10
Recently we have seen your major updates on facebook.
We use aimeos 5.8 LTS on amazon EC2.
For updating this line of code is enough ? Should I define also version number? We want to make it clean update.
composer require aimeos/aimeos-laravel
@bilginkilic_ (twitter)
Re: updating aimeos core
Post by aimeos » 21 Jul 2020, 08:48
If you want to use the latest release, use:
composer req aimeos/aimeos-laravel:~2020.07
Sometimes, composer can't update all dependencies itself and you have to remove the contents of the ./vendor/ directory before.
rowild
Post by rowild » 14 Aug 2020, 08:57
In my case, I also had to delete the "ext" folder. Is that normal?
Post by aimeos » 14 Aug 2020, 09:55
It seems to be a dependency handling problem in composer that it has problems updating all packages at once.
