Hide delivery cost selection
daniel
Post by daniel » 27 Jul 2020, 13:26
i want to hide the step to choose the delivery costs in checkout because i only have one and its for all products the same. If i remove the step "delivery" in "checkout.standard.standard.subparts" it's hidden (step is no more available) but the delivery costs are not set correctly. How can i set them as default for every product? Thanks.
Typo3 10.4.5
Aimeos 20.7.1
Re: Hide delivery cost selection
Post by aimeos » 29 Jul 2020, 06:31
Merge the delivery and payment step using the "onepage" setting (https://aimeos.org/docs/Configuration/C ... rd/onepage) and hide the delivery content per CSS. Then, it's available and used but not shown.
daniel
Post by daniel » 29 Jul 2020, 10:56
Thanks, works perfect.
One thing: if i add a product to the basket the delivery costs are not shown. If i go to checkout and make the steps, go back to basket, then the delivery costs are shown. I think this is because there was no delivery cost selected. Is it possible to set them default?
Post by aimeos » 29 Jul 2020, 16:43
Have a look at the Autofill plugin, which can add services by default to the basket:
https://aimeos.org/docs/User_Manual/Adm ... t#Autofill
daniel
Post by daniel » 03 Aug 2020, 10:05
it ist not working:
I add a new entry in "Plugins": > Provider: "Autofill", in Options i set "delivery" to "yes". Do i have to add something else there or add the created entry in Plugins "AutoFill" somewhere?
Now, if i add a product to the empty basket, no delivery costs shown. Only if i go to the checkout step with delivery it is set after that. But if i remove the product from the basket (basket is empty) the delivery costs shown in the basket, despite the fact there is no product in the basekt.
I would like to have:
- Add a product to the basket > basket shows product AND delivery costs
- Remove all products from the basket > basket shows "basket empty" and NO delivery costs
Thanks for helping
Post by aimeos » 04 Aug 2020, 06:03
Can you post a screenshot from the Autofill plugin configuration as shown in the admin backend?
If all products are removed from the basket, the delivery service isn't removed too because there's no plugin that cares about that.
daniel
Post by daniel » 04 Aug 2020, 06:43
Here is the Screenshot.
Bildschirmfoto 2020-08-04 um 08.42.27.png (39.35 KiB) Viewed 6524 times
i also tried to set the "deliverycode", but still the same.
