Installing Aimeos to Typo3 10
JariVäätäinen
Post by JariVäätäinen » 28 Jul 2020, 08:34
how should I install Aimeos web shop in Typo3 10? Aimeos shop and e-commerce framework 20.7.1 now supports Typo3 version 10, so I want to use it. In typo3 version 9 I have used Aimeos preconfigured distribution and then updated it to the latest version of the framework, but now the latest preconfigured distribution of Aimeos isn't supported by Typo3 10.
How should I now install? If I install only the framework and not the preconfigured distribution, what should I do to get the same properties to the webshop as with the distribution?
Thank You for your help!
Re: Installing Aimeos to Typo3 10
Post by aimeos » 29 Jul 2020, 16:45
Do you use composer or did you install the Aimeos distribution from TER?
JariVäätäinen
Post by JariVäätäinen » 30 Jul 2020, 06:08
Now I am waiting for your answer before installing Aimeos on this server, but I have never used Composer in Typo3 before.
Post by aimeos » 31 Jul 2020, 09:30
There's a lot of documentation available how to install TYPO3 using composer, e.g.
https://docs.typo3.org/m/typo3/guide-in ... Index.html
If you don't want to use composer, you can wait for the update of the Aimeos distribution.
