JSON API for Creating Coupon with Configs and Decorators
Kevin1596
Post by Kevin1596 » 16 Aug 2020, 10:41
I am trying to create a coupon with configs and decorators by using JSON API Admin,
this is the request data which I call the API
inside the coupon.config I use the object with decorators key and value
Screen Shot 2020-08-16 at 5.34.06 PM.png (94.92 KiB) Viewed 4957 times
and this is the response I received. As I understand the requirement is coupon.config is an array
Screen Shot 2020-08-16 at 5.34.33 PM.png (102.14 KiB) Viewed 4957 times
The problem is: when I call using the array, such as
coupon.config : [{key, val},{key, val}]
The JSON API will accepted and store the array
However, the backend wont work and keep it the same
{0: [{key, val},{key, val}]}
While using the JQADM the result in database is an object and everything will be fine
{key: value},
{key:value}
Re: JSON API for Creating Coupon with Configs and Decorators
Post by aimeos » 17 Aug 2020, 06:29
Which Aimeos version do you use? Think, it's already fixed in 2020.07.
Kevin1596
Post by Kevin1596 » 17 Aug 2020, 07:33
thank you for your reply
This is my environment code
"php": "^7.2.5",
"aimeos/aimeos-laravel": "~2020.04",
"fideloper/proxy": "^4.2",
"fruitcake/laravel-cors": "^1.0",
"guzzlehttp/guzzle": "^6.3",
"laravel/framework": "^7.0",
"laravel/tinker": "^2.0",
"laravel/ui": "^2.0"
could you help me with a example which you call JSON API admin to create and modify Coupon with configs and decorators?
Post by aimeos » 17 Aug 2020, 07:47
Please update to the current 2020.07 release first as the problem should be fixed there.
Kevin1596
Post by Kevin1596 » 17 Aug 2020, 08:17
As I upgraded to the 07.2020 version, the issues resolved!
Have a good day, thank you so much for your support!
