Add column in mshop_customer (Issue)
raghibkhesal2001
Post by raghibkhesal2001 » 19 Aug 2020, 14:39
I added following code on my custom extension ./ext/myext/lib/custom/setup/default/schema/customer.php
<?php
//https://aimeos.org/docs/Developers/Library/Extend_managers_items
return array(
  'table' => array(
    'mshop_customer' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
        $table = $schema->getTable( 'mshop_customer' );
        $table->addColumn(  'vendor_name', 'string', array( 'length' => 32, 'notnull' => false ) );
        return $schema;
and added following code in ./ext/myext/lib/custom/src/MShop/Customer/Manager/Decorator/Myproject.php
namespace Aimeos\MShop\Customer\Manager\Decorator;
class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'vendor_name' => [
            'code' => 'vendor_name',
            'internalcode' => 'mcus."vendor_name"',
            'label' => 'My new column',
            'type' => 'string',
            'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
    public function getSaveAttributes()
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( $sub = true )
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
and added ./ext/myext/config/mshop.php
return [
    'customer' => [
        'manager' => [
            'decorators' => [
                'local' => ['Myproject']
after that i run php artisan serve. But column not created.
am i missing something? please provide me step.
Re: Add column in mshop_customer (Issue)
Post by aimeos » 19 Aug 2020, 20:43
./artisan serve
only starts the web server. You need to run
./artisan aimeos:setup
first.
raghibkhesal2001
Post by raghibkhesal2001 » 20 Aug 2020, 07:59
Thanks and when i tried to php artisan aimeos:setup then i got "Aimeos\MW\Setup\Exception : No databases configured in resource config file"
I checked and found that i set database configuration on the .env file but i missed to add database configuration on the config.shop -> resource -> db.
After setup, artisan aimeos:setup work successfully and created column.
Thanks for the help.
