Update - aimeos_pay?
cyrotek
Post by cyrotek » 27 Aug 2020, 10:55
Hello, I'd like to install a fresh T3 Site with the newest Components, but I just noticed that aimeos_pay isnt uptodate.
What should I do? I depend on it to connect to mollie.
Re: Update - aimeos_pay?
Post by aimeos » 27 Aug 2020, 11:14
It's almost impossible to ship new aimeos_pay versions for new TYPO3 versions because they share a lot of dependencies in their own vendor directories. This leads to conflicts if the packages in both vendor directories are slightly different - which is almost always the case because the dependencies are updated for the TYPO3 core if a new minor release is shipped.
We suggest to use composer to install TYPO3, the omnipay-mollie package and the aimeos/ai-payments extension. Then, you only have one vendor directories and no problems.
