Sorting of variant attributes
iresults
Post by iresults » 28 Aug 2020, 13:56
How can variant attributes be sorted individually? I have set the position in the Attribute Types. But this value has no effect.
See attached Screenshot.
TYPO3 9.5.20
Aimeos 20.7.1
PHP 7.2.33
Re: Sorting of variant attributes
Post by aimeos » 29 Aug 2020, 08:39
That depends a bit on the environment. If you use TYPO3, the order of the attribute types is determined by the order of the chosen attribute types in the catalog filter flexform. Otherwise, you can set the order by using:
https://aimeos.org/docs/Configuration/C ... bute/types
iresults
Post by iresults » 31 Aug 2020, 09:43
Many thanks for the answer. However, my question refers to the Detail view of a product (in the area where a product variant can be selected), not to the Filter.
Is there also a possibility to define the order in the Detail view?
Post by aimeos » 31 Aug 2020, 13:47
At the moment, the variant attribute types are sorted by attribute type code. You can use codes like "01_volume" so they are sorted accoring to your needs.
iresults
Post by iresults » 31 Aug 2020, 14:44
In this case there is no possibility to adjust the sorting afterwards? If I change the code of the attribute, all links in the products are lost.
Where would the code need to be adjusted?
Post by aimeos » 31 Aug 2020, 14:57
