URLs changes after upgrade to 2020.07
columbo
Post by columbo » 03 Sep 2020, 19:39
after upgrade to aimeos 2020.07 product URLs changed from underscores to hyphens eg.
to: www.xyz.com/shop/prod-abc-xyz
Now all bookmarked and indexed (SEO) URLs aren't valid anymore -> "Product not found" message.
Are there any possibilities to replace / redirect an "old" URL (with _) to the new (with -)?
thx and regards
Re: URLs changes after upgrade to 2020.07
Post by aimeos » 04 Sep 2020, 15:54
It's difficult to configure another word separator because it's done in a class that can't be overwritten:
https://github.com/aimeos/aimeos-core/b ... #L145-L149
The best options would be:
- Implement a 404 handler that replaces "_" with "-"
- Write a rewrite rule for your web server that does the replacement
We are sorry, we haven't thought about that problem when switching to SEO best practices in 2020.07 ...
