Filter multiple categories
StevenShelby
Post by StevenShelby » 10 Sep 2020, 04:58
Hi I want to know is there any option for multiple categorie filter like attribute in laravel
Re: Filter multiple categories
Post by aimeos » 11 Sep 2020, 10:11
Yes, you can pass multiple categories using the f_catid parameter like:
<input type="checkbox" name="<?= $enc->attr( $this->formparam( ['f_catid', ''] ) ?>" value="<?= $enc->attr( '<catid1>' ) ?>" />
<input type="checkbox" name="<?= $enc->attr( $this->formparam( ['f_catid', ''] ) ?>" value="<?= $enc->attr( '<catid2>' ) ?>" />
For that, you have to replace the standard category template with one that adds a checkbox to each category.
