[Solved] Update problem 20.7.4
rowild
Post by rowild » 09 Oct 2020, 13:02
When updating from aimeos 20.7.2 to 20.7.4 (`composer update aimeos/ai\*`), I get this error after running aimeos' update script:
`Binding parameters is not available for simple statements: mshop/customer/manager/group/typo3/insert`
Also, when trying to access the aimeos backend in TYPO3, it says:
```(1/1) Aimeos\MW\View\Exception
Template not available: dashboard/list-standard
in /Volumes/_II_/_SITES/__KUNDEN/oaa/typo3-9-comp.oaa.lokal/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php line 232```
I assume the second error is connected to the first one...
Am I doing sth wrong?
TYPO3 9.5.22 (composer)
aimeos 20.7.4
The composer file contains the required post-install and post-update scripts.
When I downgrade to 20.7.2, the error does not appear.
Re: Update problem 20.7.4
Post by aimeos » 10 Oct 2020, 08:57
Can you post the output of "composer show" and run "composer update" so there's no dependency update missing?
rowild
Post by rowild » 12 Oct 2020, 07:26
After having downgraded to Aimeos 2020.7.2, did the usual TYPO3-related clean-ups and cache purging and composer dumping, also temporarily removing my aimeos ext overrides, the update to 2020.7.4 worked again... Sorry for having posted this issue before working through all scenarios!
