Laravel Passport Auth is not working
Devanshu
Post by Devanshu » 18 Oct 2020, 14:03
Hi, I am new for Aimeos ...
I have installed Passport for Authentication ... and It is working for my custome apies in laravel
But when I am trying to fetch Customer Detail and passsing Authorization Header as 'Bearer XXXXXXX' (Access Token) . Not getting the details.
What am I doing wrong.
Screenshot from 2020-10-18 19-20-41.png (196.71 KiB) Viewed 2575 times
Apart from that I changed the shop.php configuration file also
Screenshot from 2020-10-18 19-24-31.png (252 KiB) Viewed 2575 times
Using : Laravel 7.x , Aimeos 2020.x, Ubuntu
Thanks in advance.
Thanks and regards,
Devanshu Srivastava
Re: Laravel Passport Auth is not working
Post by aimeos » 19 Oct 2020, 16:47
Hard to say from an outside perspective. If
Auth::id()
returns the ID of the user record, Aimeos should return the customer data via the JSON REST API too.
