Multiple downloads after checkout
IOU42
Post by IOU42 » 20 Oct 2020, 10:31
Good Day,
I would like to ask if it is possible to add more than 1 download (available after check out) for a virtual product.
The download tab only allows for one correct?
Thanks!
installed versions:
Laravel: 7.28.3
Aimeos: 2020.07
PHP: 7.2.29
System info:
Running Aimeos Laravel: 2022.10
Laravel Framework 9.52
Almalinux
PHP 8.1
Re: Multiple downloads after checkout
Post by aimeos » 20 Oct 2020, 13:30
Currently not. The workaround is to put everything into a Zip file.
Alternatively, you can extend the admin interface and the templates to allow several download links because they can already be stored in the database.
We would also love to get a contribution for that feature :-)
IOU42
Post by IOU42 » 20 Oct 2020, 15:57
Clear, thank you! When (or maybe beter if ;) ) I get a more profound knowledge of Aimeos, I will give that extension a try.
System info:
Almalinux
PHP 8.1
