Problems with URLs
victorandres
Problems with URLs
Post by victorandres » 02 Dec 2020, 11:06
I have a problem with the Aimeos implementation. To carry out my project, I have created a folder on my localhost, it is called "prueba", and to access the frontend, for example, the home page, the URL is "localhost / prueba / public /". The problem comes in the part of the store, to log in, you have to change the href in the code to access the login page. On the other hand, in the administrator part, I don't know where to change those URLs to be able to access it from the browser.
I mean, if i click in "Orders", the URL is "http://localhost/admin/default/jqadm/se ... er?lang=en", and if i change it manually like http://localhost/prueba/public/admin/de ... er?lang=en", it works.
I need help with this please.
Re: Problems with URLs
Post by aimeos » 03 Dec 2020, 09:30
The document root of your web site must point to the ./public/ directory of your Laravel application, not to the root of the application itself. Your current setup exposes the .env file including all your credentials!
طهمحمدعبدالتواب
Post by طهمحمدعبدالتواب » 10 Dec 2020, 11:02
Did you find a solution? I have the same issue even after changing the env APP_URL to ...public/
Post by aimeos » 10 Dec 2020, 11:17
Changing the APP_URL is wrong. The document root of your webserver vhost must point to .../yourlaravelapp/public/, not to .../yourlaravelapp/
