JSON API - create new product and add existing Attributes with Product.lists.type
Kevin1596
Post by Kevin1596 » 03 Dec 2020, 09:07
Hi there,
I am currently using Aimeos laravel ver 2020.10*
- I am using JSON API to create a variant article with existing attributes to include to Selection product
below Image is the data in the request.
- The problem is after submitting, the product.list.type = variant is automatically change to 'default'
Screen Shot 2020-12-03 at 4.05.17 PM.png (61.46 KiB) Viewed 11862 times
Re: JSON API - create new product and add existing Attributes with Product.lists.type
Post by aimeos » 04 Dec 2020, 08:29
Can you please post your full request and response including the code for building the request?
Kevin1596
Post by Kevin1596 » 04 Dec 2020, 09:15
this is the data in the POST request
"type": "product",
"attributes": {
"product.status": 1,
"product.type": "default",
"product.label": "label size S yellow",
"product.code": "testselectioncreate-size-S-yellow"
"relationships": {
"attribute": {
"data": [
"id": "25",
"type": "attribute",
"attributes": {
"product.lists.refid": "25",
"product.lists.domain": "attribute",
"product.lists.status": 1,
"product.lists.type": "variant"
"id": "28",
"attributes": {
"product.lists.refid": "28",
the response will be the Product with the created Data
"meta": {
"total": 9
, "csrf": {
"name": "_token",
"value": ""
, "data": [
"id": "277",
"type": "product",
"attributes": {
"product.id": "277",
"product.siteid": "3.",
"product.ctime": "2020-12-04 15:43:38",
"product.mtime": "2020-12-04 15:43:38",
"product.editor": "shop2",
"product.url": "label-size-S-yellow",
"product.code": "testselectioncreate-size-S-yellow",
"product.dataset": "",
"product.datestart": null,
"product.dateend": null,
"product.config": [],
"product.scale": 1,
"product.target": "",
"product.rating": "0.00",
"product.ratings": 0
"links": {
"relationships": []
Kevin1596
Post by Kevin1596 » 04 Dec 2020, 09:47
when I check the source code in JSON ADM
As the line 432 the source code
$listItem = $listManager->createItem()->setType( 'default' );
I change to 'default' to 'variant' the variant is set for the product.lists.type
How could I extend the source here to get the product.lists.type from the request
"type": "product",
"attributes": {
"relationships": {
"attribute": {
"data": [
"id": "25",
"attributes": {
"id": "28",
"attributes": {
Screen Shot 2020-12-04 at 4.44.17 PM.png (141.95 KiB) Viewed 11837 times
Post by aimeos » 06 Dec 2020, 17:44
In line 437 (fromArray()), your product.lists.type should be set to "variant" if you pass that via the JsonAdm API. Can you please check what does happen there in your case?
Kevin1596
Post by Kevin1596 » 07 Dec 2020, 02:59
Thank you for your response,
However the product.lists.type is still "default"
could you please call an sample API fo checking it?
- create a new product with existing attributes and the product.lists.type: "variant"
Kevin1596
Post by Kevin1596 » 07 Dec 2020, 03:13
as I am checking the In line 437 (fromArray()),
$item = $item->fromArray( $attr, true );
the $item is the product id rather than the product.list
I changed to this one and the product.lists is saved as expected:
$listItem = $listItem->fromArray( $attr, true );
would you like to check the source is it alright or any problems with my change?
Post by aimeos » 07 Dec 2020, 14:18
Yes, it should be $listItem instead of $item. Can you create a PR for your fix?
Kevin1596
Post by Kevin1596 » 14 Dec 2020, 08:10
yes I already created a pull request
please help me check it
https://github.com/aimeos/ai-admin-json ... 11/commits
Post by aimeos » 14 Dec 2020, 08:18
Thanks, your PR has been merged and will be part of the next release
