[Solved] After update to TYPO3 10 basket +/- and delete won't work anymore
rowild
Post by rowild » 04 Dec 2020, 05:10
In TYPO3 9 / aimeos 20.10 everything worked fine. The update to TYPO3 10 causes troubles. I updated several times (composer installation), but the problem remains no matter what. I also removed and required aimeos/aimeos-typo3:2020.10.x-dev.
I do not use bootstrap_package, but I do use all original aimeos scripts (template, css, js). No errors are thrown.
This is what happens:
- When I click the + or minus button in the standard basket, the spinner appears and also disappears again, but the amount of a product was not changed.
- When I click on a delete button, the page is redirected to the start page.
Is there anything special to look out for when working with TYPO3 10?
Re: After update to TYPO3 10 basket +/- and delete won't work anymore
Post by aimeos » 04 Dec 2020, 08:16
Can you please check if you're page setup in the basket flexform is set up correctly or if there's something missing?
rowild
Post by rowild » 04 Dec 2020, 10:03
There was indeed a wrong id pointing to the basket page (which was assigned properly in the TYPO3 9 version – but there the catalog list page was empty; maybe that caused the probelm?).
Thank you very much!
