New Web site Integration
Alex Kantanda
Hello, thanks for response, I saw your good post.
I implemented by using composer create-project aimeos/aimeos myshop.
I have templete files like Screenshot_1.png.
I have made extention folder by using extension builder and copied that to /ext .
I have some questions:
how to activate my extension?
How to customize with using Screenshot_1.png?
thanks, please guid me.
- Screenshot_1.png (4.26 KiB) Viewed 2570 times
Re: New Web site Integration
The extension is automatically active. For the CSS/JS code read:
https://aimeos.org/docs/latest/frontend ... te-themes/
