Theme Help
Alex Kantanda
Theme Help
Post by Alex Kantanda » 04 Dec 2020, 11:04
Hello!
Create theme extension
To create a portable theme, you should generate an extension for your theme first using the Aimeos extension generator. Copy it to the ./ext/ directory of your application where also the other Aimeos extensions are located. You should also put that extension under version control, e.g. by adding it to a Git repository.
In your extension, create a new theme directory ./client/html/themes/<themename>/. Replace <themename> with an unique name for your theme.
I have made my theme extension following this guide.
Afterwards, I run "composer update".
I know that my extension theme is copied public/package/aimeos/shop/themes/ when run composer update.
but not copied as shown in picture.
Please help me, thanks.
Re: Theme Help
Post by aimeos » 06 Dec 2020, 17:55
In Laravel, your theme from your extension is only copied to the Laravel ./public/ directory if you execute:
php artisan vendor:publish --all
This is done once at installation but need to be executed manually if you install a theme afterwards.
