Login/Sign-up: Guest checkout without signup, Login with email ID/phone number via OTP, Login with Google & Facebook
parassingh
Laravel Aimeos Shop installed (latest version released in october 2020)
For great user experience I want to implement 3 login or sign-up options as mentioned below:
1. Guest checkout without login: By giving this option
> We can make a smooth user flow without asking to create an account during order placement.
> We can make it easy by creating account automaticaly by using the billing or delivery information during guest checkout and make the credentials available on email or SMS
2. Sign-up or login with email-ID or mobile number via sending OTP for verification
3. Login with Google and Facebook: this help
> Mobile User get easy login as Google & Facebook always open on the smartphone
I need help to implement all the above options... Please help me out
Re: Login/Sign-up: Guest checkout without signup, Login with email ID/phone number via OTP, Login with Google & Facebook
This is the default in Aimeos.parassingh wrote: 05 Dec 2020, 18:12 1. Guest checkout without login: By giving this option
Use and extend the Laravel login/register functionality as this is offered by Laravel, not by Aimeos. There are Laravel packages available for integrating social logins or using other means.parassingh wrote: 05 Dec 2020, 18:12 2. Sign-up or login with email-ID or mobile number via sending OTP for verification
Hi @aimeos, may you show me where's the documentation of this guest checkout?
Guest checkout is the standard way in Aimeos. At the end of the checkout process, either a new account for the customer is created (if they don't un-check the option in the summary page) or the order is assigned to the existing account based on the e-mail address of the customer.
