Image in payment email is not correct
promptnet
Post by promptnet » 07 Dec 2020, 13:21
I configured the image for the email in the Scheduler this way:
client.html.email.logo = /var/www/vhosts/correctpath-to-extension/Resources/Public/Images/logoemail.png
Now, in emails there are two(!) logo-images as attachments (twice the same), but the one within the html-part is not shown, neither in Outlook 365 nor in webmail. It shows a message to download the image but nothing happens!?
Is that problem known?
Thanks for help.
Kurt
Aimeos: 20.10.2
TYPO3: 10.4.10
PHP: 7.3.25
Re: Image in payment email is not correct
Post by aimeos » 08 Dec 2020, 09:51
Nobody brought this up before. The logo is attached here for the order confirmation:
https://github.com/aimeos/ai-client-htm ... d.php#L242
promptnet
Post by promptnet » 08 Dec 2020, 13:08
Ok, try to save it in an other format. Maybe PNG with alpha channel is not good...
promptnet
Post by promptnet » 08 Dec 2020, 13:18
As you can see, the problem is still remaining...
Post by aimeos » 08 Dec 2020, 13:19
What is the source code of your email?
promptnet
Post by promptnet » 08 Dec 2020, 13:32
Attached the email HTML code.
I realized that there are further problems:
  • In the scheduler I cannot provide a page ID for product catalog (Product catalog page ID). After saving the value is gone and the field is empty again.
  • The BCC recievers do not get the email. It is configured like that (the same way as in TYPO3 9.5):
    client.html.email.bcc-email {
      0 = email@email.com
      1 = email2@email.com
What's the problem?
email.zip
(3.3 KiB) Downloaded 593 times
Post by aimeos » 09 Dec 2020, 08:49
promptnet wrote: 08 Dec 2020, 13:32 Attached the email HTML code.
To see what has happened, we would need the full source code of the email from your inbox.
This is a problem of the scheduler in rare cases when saving your new task the first time. We don't know why that happens but if you add your page ID again, it will be saved without problems.
promptnet wrote: 08 Dec 2020, 13:32 [*]The BCC recievers do not get the email. It is configured like that (the same way as in TYPO3 9.5):
  0 = email@email.com
[/list]
This should work, you can check the code here:
https://github.com/aimeos/ai-client-htm ... #L287-L319
promptnet
Post by promptnet » 09 Dec 2020, 11:27
Attached the full source code of the email. I replaced every occurence of my personal data and of the shopholder data.
The BCC receivers do not get an email!? Why? I also added the following in the scheduler config and in main TS template:
client.html.email.payment.bcc-email {
  0 = email@email.com
  1 = email@email.com
In main TS template with
plugin.tx_aimeos.settings.client.html.email.payment.bcc-email
It seems that there is a severe problem with the installation...
email.zip
(19.36 KiB) Downloaded 606 times
Post by aimeos » 11 Dec 2020, 11:40
promptnet wrote: 09 Dec 2020, 11:27 Attached the full source code of the email. I replaced every occurence of my personal data and of the shopholder data.
It contains the image two times as attachment but the image reference in the HTML section is different than for the attachments. I think we've found the problem and fixed it with this commit:
https://github.com/aimeos/ai-typo3/comm ... f1924a2355
Can you please check if it works now?
promptnet wrote: 09 Dec 2020, 11:27 The BCC receivers do not get an email!? Why? I also added the following in the scheduler config and in main TS template:
  0 = email@email.com
  1 = email@email.com
Your configuration is correct. Can you check if the BCC addresses are added here:
https://github.com/aimeos/ai-client-htm ... d.php#L317
promptnet
Post by promptnet » 11 Dec 2020, 15:07
aimeos wrote: 11 Dec 2020, 11:40 I think we've found the problem and fixed it with this commit:
Thanks - image is working now!
aimeos wrote: 11 Dec 2020, 11:40 Your configuration is correct. Can you check if the BCC addresses are added here:
Yes, BCC addresses are added. I made a var_dump(), and they were displayed.
