JSON API - Double Relationship resources
Kevin1596
Post by Kevin1596 » 15 Dec 2020, 04:46
Aimeos laravel 2020.10*
when I called API to catalog endpoint to get the data
with var params = {
include: 'catalog,product,text,media'
the response have the double of TEXT resources of the included Catalog
var url = `https://laravel.demo.aimeos.org/default/jsonapi`; // Base URL from config
var promise = $.ajax( url, {
    method: "OPTIONS",
    dataType: "json"
promise.done( function( options ) {
    var args = {};
    var params = {
    console.log(options)
    console.log('end points')
    console.log(options.meta.resources)
    var result = $.ajax({
        method: "GET",
        dataType: "json",
        url: `${options.meta.resources['catalog']}`,
        data: params
    result.done( function( result ) {
        console.log('resource data')
        console.log( result.data );
Screen Shot 2020-12-15 at 11.46.06 AM.png (115.98 KiB) Viewed 8522 times
Re: JSON API - Double Relationship resources
Post by aimeos » 17 Dec 2020, 13:51
If you add "include=catalog", the response will also include all subcategories and these categories have texts, images and prodducts themselves which are also added in the "included" section.
Kevin1596
Post by Kevin1596 » 18 Dec 2020, 04:07
the problem is in the Included Catalog:
the relate texts of included catalog are doubled
Example: as the screen shot we have text with Id 40727 is double
Kevin1596
Post by Kevin1596 » 18 Dec 2020, 04:57
you could check it by calling my request on https://laravel.demo.aimeos.org/default and review the response
Post by aimeos » 18 Dec 2020, 08:18
You are right, the relationship entries for texts are duplicate:
https://laravel.demo.aimeos.org/default ... retty=true
Post by aimeos » 18 Dec 2020, 10:29
OK, it's fixed in aimeos/ai-client-jsonapi:2020.10.x-dev
Can you confirm?
Kevin1596
Post by Kevin1596 » 18 Dec 2020, 15:02
I will confirm it!
another point is, It seems that Stock also got relate problem
Post by aimeos » 20 Dec 2020, 14:03
Your screenshot is missing. Can you also post an URL of the demo installation where we can see the problem?
